Post-processing
Old   February 25, 2004, 11:12
Default Post-processing
eric
I want to make a presentation of my result. I have two different simulation models in separate files which I have to compare.
My question is, how can I present the results from both models at the same magnification, position etc? In other words I want to show the same part of the model in for the two simulations. In order to view this part effectively I have to pan in. Is there a way to mark this point so that I can return to this magnification and position again if I need to look at the same result again in the future?
Regards,
Eric
Old   February 25, 2004, 11:24
Default Re: Post-processing
mateus
Hi!
You can define your point of view in "View" panell. You set the desired view and save it. To get back to the desired view you have to load it and then click restore.
Best regards
MATEUS
Ansys Post processing ano999 ANSYS 1 May 27, 2011 16:24
NO model vs post processing in coal combustion,CFX sakalido CFX 1 April 15, 2011 14:07
post processing for KIVA dirga Main CFD Forum 5 April 23, 2009 10:58
Post Processing in FEM Abhijit Tilak Main CFD Forum 0 April 26, 2004 11:59
post processing in CFD MANISH BHARGAVA Main CFD Forum 0 October 17, 1998 20:51
