help on checking source term
Old   February 25, 2004, 19:51
Default help on checking source term
zwdi
Hello everyone,
I tried to add the species source term (g/s) in one fluid zone in Fluent. But I am not sure if the adding of the species source correct or not in Fluent. The result is converged. But I don't know how to check and see if the source works well or not by post processing. Could anybody give me guidelines on this point? Thanks a lot.
Zwdi
Old   February 26, 2004, 20:19
Default Re: help on checking source term
Ryan, Lee
In the case of adding source terms into species transport equation, generally, Unit of source term is kg/(m^3*sec).
Then try to check out two simple cases based on physical phenomenon in your system. One is result without source term. The other is result with source term.
Good luck!
Old   February 27, 2004, 16:46
zwdi
thank you, lee. I will try it and let you know.
Zwdi
critical error during installation of openfoam Fabio88 OpenFOAM Installation 21 June 2, 2010 03:01
Problems in compiling paraview in Suse 10.3 platform chiven OpenFOAM Installation 3 December 1, 2009 07:21
DecomposePar links against liblamso0 with OpenMPI jens_klostermann OpenFOAM Bugs 11 June 28, 2007 17:51
Help%7e%7einstall openfoam13 on fc5%7e%7e aderliner OpenFOAM Installation 2 September 11, 2006 07:24
Gerris software installation mer Main CFD Forum 2 November 12, 2005 08:50
