Running FLUENT 6.0 sims. on FLUENT 6.1
Old   April 1, 2004, 11:00
Default Running FLUENT 6.0 sims. on FLUENT 6.1
ozgur
When I try to work on my old VOF simulations performed in FLUENT 6.0 in FLUENT 6.1, I got the following error:
Error: Cell_Function_Values: unrecognized function: vof-water Error Object: #f
Is there any workaround for that?
Thanks
Old   April 1, 2004, 14:24
Default Re: Running FLUENT 6.0 sims. on FLUENT 6.1
ap
This happens because in FLUENT 6.1 manages phases in a different way. For example, it's possible to solve scalar equations on a phase domain instead that on the mixture domain.
You surely can re-initialize the calculation and start it from scratch.
If you don't want to loose data, probably you can export them in a file in FLUENT 6 and then import them in FLUENT 6.1.
Hi
ap
Old   April 2, 2004, 13:23
ozgur
Thanks,
I'll try export/import solution.
Parallel running of Fluent Bhanu Gupta FLUENT 3 April 7, 2011 09:32
Different Results from Fluent 5.5 and Fluent 6.0 Rajeev Kumar Singh FLUENT 6 December 19, 2010 11:33
Running fluent in UNIX L3munoz FLUENT 10 August 26, 2009 04:59
Displaying grids in Fluent 6.0 João Fernandes FLUENT 1 July 27, 2006 10:16
FLUENT 5.2.3 running on PIII 733 Burley Wang FLUENT 7 April 19, 2000 06:03
