flow around bullet
Old   March 26, 2004, 03:31
Default flow around bullet
arthur
My name is Arthur, i'm newcomer. i'm student now. My final task is about flow around bullet, i have geometry of bullet, but i having problem to simulate it, can you help me please? what version Fluent that i shall use to simulate this? thank you very much!!!
Old   March 26, 2004, 04:53
Default Re: flow around bullet
FJ
I think that the flow aroud a bullet is super sonic flow, isn't it?. This kind of flow, selecting Fluent solver is to be important. Fluent's version is not important(every version Fluent what were released before can calculate it(except FLUENT4)). Select "Coupled-Implicit" or "Coupled-Explicit". (Default solver is "Segregated" and this solver does not suit your problem. It is also able to calculate but the accuracy is not good for high mach number flow).
I recommend "Coupled-Explict", this solver is similar with RAMPANT.
Thank you
FJ
Old   March 27, 2004, 06:29
arthur
thanx, about that. but i have another problem, how about the equation of it's motion? How to use it in fluent?
Old   March 28, 2004, 17:42
amir
Hi what is yuor aim about the equation of its motion? please explain about it.tank yuo. amir.
Old   March 30, 2004, 00:14
arthur
i mean how to simulate bullet so that it can moving towards and spinning
Old   April 2, 2004, 13:02
Amir
Hi I am not sure but i think that you should create a control valume and set bullet in it . yuo can use rotational motion for wall bc of bullet or its solid(in wall panel or solid panel).if you supposed that overseer det on bullet you can yus vilocity inlet for simulate its forward motion. by. Amir.
mass flow in is not equal to mass flow out saii CFX 12 March 19, 2018 05:21
Flow meter Design CD adapco Group Marketing Siemens 3 June 21, 2011 08:33
What is the difference between liquid reactive flow and gas reactive flow? James Main CFD Forum 6 May 15, 2009 12:14
potential flow vs. Euler flow curious ... Main CFD Forum 23 July 21, 2006 07:40
Plug Flow Franck Main CFD Forum 3 September 4, 2003 05:57
