How to activate"spring-all-shapes"?
Old   April 7, 2004, 03:41
Default How to activate"spring-all-shapes"?
David
I use dynamic mesh model to simulate a FSI problem, and the user-defined motion type was adopted based UDF. I found the spring-based mesh motion method did not work when structural mesh or mixed mesh with structural boundary layer mesh was used, so I want to activated the function"spring-all-shapes" through text command according to Fluent Guide.
Fluent prompts:"By default, spring-based smoothing on non-triangular or non-tetrahedral cell zones are turned off. If you want to use spring-based smoothing on all cell shapes, you can turn on the model for these zones using the text-interface command spring-on-all-shapes? in the dynamic-mesh-menu."
But the fllowing error occurs when I input the command "spring-on-all-shapes".
/define/models/dynamic-mesh-controls> spring-on-all-shapes
Error: eval: unbound variable Error Object: help
How to solve this problem?Thanks
Old   April 7, 2004, 08:58
Default Re: How to activate"spring-all-shapes"?
Tonje
You can try this command: (rpsetvar 'dynamesh/spring/all-element-type? #t) with parenthesis and everything. Good luck
Tonje
Old   April 8, 2004, 09:45
David
Thank you for you reply. I input this command in the text command:
> (rpsetvar'dynamesh/spring/all-element-type?#t)
but fluent says:
Error: rp-var-value-set!: undefined variable
Error Object: dynamesh/spring/all-element-type?#t
Old   April 9, 2004, 03:11
gg
input command with spaces as Tonje say !
Old   December 28, 2020, 23:04
central province
Krasa is on a distinguished road
please help me I used this command but still error is there
command : (rpsetvar 'dynamesh/spring/all-element-type? #t)
error : invalid command [- rpsetvar]
Krasa is offline   Reply With Quote
