initialization - Turbulent KE
Old   May 12, 2004, 10:51
Default initialization - Turbulent KE
co2
hi all,
i have a fluent model where there is a air fluid zone above a porous zone. the problem is natural convection in stored grain. The model is going well and showing good convergence but I have one concern.
When I initialized the problem I initialized k = 6e-6 and epsilon = 1e-9 Those values were calculated from the turbulent intensity assumed at the top pressure outlet of the tank. now the porous zone is laminar zone (check box in porous zone ON) and when I see the results after a few hours of simulation, i see the turb intensity in the porous zone to be around 1e-8 -- Thus it has come down by a order of 100 from the initialization but I was just wondering if the results are correct since in the laminar zone there should not be any turb intensity -- right ? or it is only going to come down slowly as the solution progresses ?
please let me know if you need any more info to answer my question
Old   May 13, 2004, 07:07
Default Re: initialization - Turbulent KE
Mattias
Hello co2!
When turning on the laminaar check box in the porous zone there is no turbulent production in the zone. However, when you initialize, you set an intensity and I guess that you donดt have set relaxation factor for k and epsilon to 1 (default is 0.8 I think). Try patching k and epsilon values to 0 in the porous zone. Then there should be no turbulent intensity in the porous zone.
/Mattias
Old   May 13, 2004, 12:06
co2
Mattias :
Thanks for your reply!
I just patched it in the middle of the solution, I am still getting good convergence. so I guess I am ok.
Thanks, Co2
CFX Treatment of Laminar and Turbulent Flows Jade M CFX 18 September 15, 2022 07:08
Turbulent Dispersion for Coal Combustion gravis CFX 2 March 23, 2010 23:56
setting value of turbulent intensity and turbulent viscosity ratio in wind tunnel nuimlabib Main CFD Forum 0 August 4, 2009 00:05
About low Re number turbulent flows gorka Main CFD Forum 13 April 2, 2003 05:19
Problem of Turbulent Viscosity Ratio Limited David Yang FLUENT 3 June 3, 2002 06:13
