Problem in giving heat source
Old   July 8, 2004, 02:13
Default Problem in giving heat source
Sireesha
Haai, For my geometry, for a voulme (3d) I am giving heat source value. When I am giving that value it is showing following message.
Error: GENERAL-CAR-CDR: invalid argument [1]: improper list
Error Object: #f
For some cases it worked successfully, but after that it is started giving problem.
If any body knows about it please tell me about this problem, because for this reason only my project has been stopped. I tried with different version of Fluent.
Thank you
Old   July 10, 2004, 17:54
Default Re: Problem in giving heat source
AJ
Are you applying source on one of the volumes in 3D model??? Try with small problem and check if it works fine... If it doesn't work with a small tutorial type of problem... then your fluent may have some issue...
AJ
source terms-convergence problem alanlove FLUENT 0 March 28, 2010 06:47
Missing heat source Phil FloEFD, FloWorks & FloTHERM 9 June 19, 2008 10:33
Heat source problem ocy FLUENT 7 February 17, 2005 02:08
Heat Generation as time dependent problem Denis Kadito FLUENT 0 April 17, 2001 16:28
UDFs for Scalar Eqn - Fluid/Solid HT Greg Perkins FLUENT 0 October 11, 2000 03:43
