July 30, 2004, 14:36 |
urgent please heat transfer
hello
i'm heaving some pipes from an engine with wather inside. ok. i'm modelling a heating transfer from the engine to the wather. i've indicated 500 k temperature to the heated wall and to the other walls 300 k. my problem is that 1 can not boil the wather. the is no transfer. 1'm heaving all the parameters velocity and pressure correct but i can not see something there. please help. i really nead it. did you knew how can i modelate this thanks cip |
August 9, 2004, 03:40 |
Re: urgent please heat transfer
hai friend, i read ur message , but i cant get ur problem, i cant understand ur problem- the way u explained it, b brief enough, ok, u have said that thetemp of the heated wall is 500k and other walls as 300k, wat is the profile of the walls? i cant get it, ok, reply soon, bye
August 9, 2004, 15:15 |
thanks
i've done it. thank's.
all the best. cip |
Convective / Conductive Heat Transfer in Hypersonic flows | enigma | Main CFD Forum | 2 | November 1, 2009 22:53 |
How can I increase Heat Transfer at Domain Interf? | B.Simon | CFX | 3 | October 28, 2008 18:53 |
heat transfer imbalance? URGENT | ranton | FLUENT | 3 | August 4, 2005 08:22 |
