September 9, 2004, 09:34 |
how to calculate subsonic misssile
i calculate a missile ranging from mach0.6 to mach 3, with the angle of attack 2 degree,4 degree,and 8 degree,the supersonic result(force coefficients and moment coefficients) is acceptable,but the subsonic result is far from the experimental data,who would please give me some advice on it,thanks fot regards now! k-e modle , steady, explicit multi-grid implemented inletressure-far-field outletressure out
September 16, 2004, 01:56 |
Re: how to calculate subsonic misssile
Your are always going to battle with the coefficients in subsonic flow expecially the Cd numbers as the solution is domintaed by the viscous terms at low AoA
September 17, 2004, 01:32 |
sorry,i have to add here that the supersonic results are not good too,30% lower than experimental data(for lift coefficient , 10% lower).the results are probably due to the difficulty to simulate fiction drag ,how can i deal with it? isn,t fluent good at dealing with it?
How to calculate grid width in control volume | Ingenierias2003 | OpenFOAM | 5 | November 24, 2010 12:40 |
calculate values for eps and k from Re or u????? | sbar | OpenFOAM Pre-Processing | 5 | August 16, 2010 04:10 |
Using Compressible Solver (sonicFoam) to solve subsonic flows | ezsoal | OpenFOAM | 0 | October 27, 2009 09:13 |
How to calculate Torque for francis turbine | manish | CFX | 4 | March 15, 2007 02:57 |
How to calculate energy dissipation | chinthakindi | Main CFD Forum | 0 | February 23, 2004 06:36 |
