Heat sink analysis
Old   September 10, 2004, 19:23
Default Heat sink analysis
Akash
I am using Fluent to model forced convection in a longitudinal heat sink for its application in electronics. I created the geometry in Gambit and specified an inlet velocity and pressure outlet condition for the fluid zone and a temperature at the base of the heat fin. But when I imported this geometry in Fluent and performed the analysis, the post-processing results demonstrated a uniform temperature( which was the base temperature I specified) all over the fin ( i.e it was insulated) I could not use the "coupled option" as no shadow zones were created. I would appreciate it if you could give me any input as to what might have gone wrong.
Many thanks, Akash
Old   September 13, 2004, 08:39
Default Re: Heat sink analysis
Jan Langebach
Hello, as far as my experiences show you need to connect the volume of the surrounding fluid and the volume of your heat sink. Otherwise you wont get any shadow wall for the connection between heat sink and fluid. But if you are modelling only a fluid with attaching walls and no volume of the heat sink (just the wall of it) you dont need any shadow wall.
Bye.
Old   September 13, 2004, 11:14
Akash
Thanks Jan. I really appreciate your help.
Heat sink analysis Scott Hansen CFX 8 May 6, 2015 10:32
Help modeling heat sink aimee FLUENT 1 June 3, 2011 14:17
Simulate heat transfer of heat sink in a box... chien87 CFX 8 February 8, 2011 03:50
Reply me if u did heat sink analysis siva FLUENT 0 January 5, 2009 07:07
Simulation on Heat Sink Ken Adams FLUENT 4 June 26, 2007 16:03
