Real Volume Substraction
Old   October 7, 2004, 18:10
Default Real Volume Substraction
taskin
hello all, I have problem with substracting two volumes in gambit.. I'm trying to substract an egg like volume from a cube.. however when I choose to substract it deletes the egg like volume and nothing changes in the cubic volume.. neither it gives any error.. can anyone tell why this happens?
Old   October 8, 2004, 05:10
Default Re: Real Volume Substraction
Mark
If volume subtraction is giving you problems, try using splitting the volume with the other volume and then delete what you don't need.
Mark
Old   October 9, 2004, 10:52
Taskin
It can neither split with volume or face.. it gives an error like that "inconsistent free-body relationships"
Old   October 11, 2004, 05:55
Mark
Try slitting the cube volume along the centre plane of the egg-like volume before subtracting the volumes. This may help and you can unite/merge the resulting volumes later.
how to set periodic boundary conditions Ganesh FLUENT 15 November 18, 2020 06:09
[blockMesh] BlockMesh FOAM warning gaottino OpenFOAM Meshing & Mesh Conversion 7 July 19, 2010 14:11
On the damBreak4phaseFine cases paean OpenFOAM Running, Solving & CFD 0 November 14, 2008 21:14
[blockMesh] Axisymmetrical mesh Rasmus Gjesing (Gjesing) OpenFOAM Meshing & Mesh Conversion 10 April 2, 2007 14:00
