Gambit won't save?
Old   December 7, 2004, 11:04
Default Gambit won't save?
Mark
Gambit runs no problem when whenever I go to save I get an out of disk space error, I have 100gb free though...
Any idea what is causing this? Is it a liscencing problem?
Old   December 7, 2004, 20:43
Default Re: Gambit won't save?
zxaar
the reason for this is gambit starts in drive c: and when it tries to save there it gives this error, next time go to console and start that in some dir say c:\gambit, so after working try to save in that dir not in c: ...it shall work
Old   December 8, 2004, 10:48
Mark
Not sure I follow, how can I start gambit in a directory?
I've just been running from F:\fluent.inc\ntbin\ntx86\gambit.exe
Old   December 8, 2004, 18:07
zxaar
it doesn't matter you start gambit .. you should save the files in some folder like c:\gambit etc, if you are saving in c: then there is this problem .....
Old   December 14, 2004, 19:32
Mark
That fixed it. Many thanks!
i cannot save file as ".dbs" in gambit. ripong ANSYS Meshing & Geometry 2 October 15, 2016 23:29
Gambit help: Cube inside cube Jack Martinez FLUENT 13 August 11, 2010 06:29
Gambit 2.3.16, Xming or Exceed...HELP! bambam3417 FLUENT 10 May 7, 2010 12:39
Does Gambit has a maximum allowable grid number? spartan1516 ANSYS Meshing & Geometry 7 March 25, 2010 09:08
Gambit -dev X11 doesn't work Ervin Amet FLUENT 0 October 28, 2007 08:33
