December 20, 2004, 14:52 |
How to output Unsteady flow data?
Hi, I am using Fluent to simulate one unsteady flow. But I am stucked on how to output the unsteady data for postprocessing: such as velocity profile of certain point, temperature profile, ect.
Appreciate your kindly help. Frank |
December 20, 2004, 19:20 |
Re: How to output Unsteady flow data?
first of all frank frankly tell if u r saving you cas/data file after some time steps or not ..you can use autosave for that ... now imagine if you have some cases and data files ..then what you can do is write a journal file to output the data from files one by one (i mean just run the journal file ..and fluent shall automatically export the data for postprocessing) .... this is how i did for my 160 cas/data files for exporting to fieldview
December 21, 2004, 09:10 |
I exported the data I needed using the export command grom the TUI. I enabled it for each iteration using the execute-command at each iteration. Otherwise you can write a UDF and access the data you need (exporting on a file).Luca
December 21, 2004, 14:53 |
First define the points in your profile. Then use the solve/monitor to plot/write the data (velocity or pressure, etc) that you want to get for those points.
Use the area weighted average and use time steps instead of iterations. |
December 21, 2004, 16:58 |
Thank you all for your advices. I will try it and maybe ask for your help again.
Merry X'mas and happy new year! Frank |
December 25, 2004, 02:27 |
Periodic boundary in unsteady flow | ac2011 | FLUENT | 0 | September 26, 2011 06:52 |
how to compare unsteady state problem results from FLUENT with Experimental data? | cuddaloreselvam | FLUENT | 0 | July 10, 2011 08:25 |
Unsteady simulation of flow past wheel | Tom | FLUENT | 8 | January 18, 2006 10:54 |
Inviscid Drag at subsonic, subcritical Mach # | Axel Rohde | Main CFD Forum | 1 | November 19, 2001 12:19 |
PhD in turbulence | Hans | Main CFD Forum | 14 | October 8, 2001 03:03 |
