moving cylinder
Old   December 20, 2004, 03:01
Default moving cylinder
ghaedi
i want to know how can a moving cylinder in a stationary fluid can be modeled by fluent and what is boundary condition?
Old   December 20, 2004, 03:18
Default Re: moving cylinder
zxaar
if u mean rotating cylinder on its axis ..you can use sliding mesh approach ...
Old   December 20, 2004, 05:56
anni
In my opinion you just give on cylinder wall(boundary condition)the rotational velocity. and that's all.
Old   December 25, 2004, 02:39
ghaedi
thanks for your reply, i simulated a flow passes over a cylinder and the answers from fluent were correct, but the answers frome a cylinder that moves in a stationary flow were not equale with later model, how can i model a cylinder that moves to one direction and what are boundary condition?
Old   December 25, 2004, 04:30
Luca
You should use the dynamic mesh to make your cilinder obscillating. You can impose the movement of the wall using a UDF. It's quite easy especially bacause you consider the cilinder undeformable.Luca
Old   December 27, 2004, 14:38
peter
The source of the discrepancy is most likely due to the fact that Fluent throws out the normal component of wall motion when you give it a moving wall boundary condition. Plot contours of the velocity component in the direction of the cylinder's motion to see that this is true. So the only options are to solve for relative motion, as you have done (good for "steady state" solution) or use the deformble mesh approach - forces unsteady solution, although you can let it achieve a constant solution to obtain a steady result.
Need advices for simulating vortex shedding of moving cylinder quyetthang CFX 0 October 1, 2011 05:39
Flow over a Cylinder. 2D vs 3D cylinder (moving) ojha.mayank485 CFX 0 June 20, 2011 15:25
Moving a Cylinder in cross flow after solving Dynamics equations of motion maruthamuthu_venkatraman OpenFOAM 1 November 19, 2009 13:55
moving cylinder blur boy Main CFD Forum 4 October 12, 2001 05:32
Confined or moving cylinder Mohamed GUEROUACHE Main CFD Forum 1 October 23, 1999 15:20
