December 27, 2004, 23:15 |
Porous jump & Porous zone - help needed
I have some problem. My system is use the ceramic filter as porous media (3D as thickness 1.5 cm). How can i choose between porous jump and porous zone or i have to use it both? I try to read the user guide but it's not clear. Could anybody help me please.
December 28, 2004, 02:42 |
Re: Porous jump & Porous zone - help needed
Porous jump model is used in face zone not in cell zone so use porous zone because your geometry is 3D. First define your zone as fluid and then in boundary condition add the porous zone by setting the inertial and viscous resistance coefficients. You can find how to calculate these coefficients in the help manual. Define the porosity also. Or you can use power law model. For more detail use the manual. hope it will be helpful for you.
-Prakash |
December 28, 2004, 03:57 |
Thank you very much for your suggestion. I'll try to do this.
June 14, 2010, 22:37 |
xudiyi
I have a question. In this case, how what should I set as boundary conditions for the four edges of my porous zone in Gambit and Fluent since apparently I can not set them as porous jump at the same time and I don't think there are interfaces either?
Thanks! |
Modelling Combustion in Porous Zone | tanjinjack | FLUENT | 2 | September 26, 2016 04:10 |
Porous zone boundary condition- help needed | Shankar | FLUENT | 12 | March 22, 2012 06:44 |
Problem in running ICEM grid in Openfoam | Tarak | OpenFOAM | 6 | September 9, 2011 17:51 |
Porous jump V.S Porous zone | phxfudong | FLUENT | 1 | October 8, 2009 22:11 |
Problem in IMPORT of ICEM input file in FLUENT | csvirume | FLUENT | 2 | September 9, 2009 01:08 |
