January 25, 2005, 03:26 |
Heat transfer BC with two materials
I am trying to study heat transfer between two materials.One is a liquid and other is solid.How convective heat transfer can be specified on the interface wall.
January 26, 2005, 16:50 |
Re: Heat transfer BC with two materials
You shouldn't have to specify anything - if you have the energy equation turned on, heat will transfer(other than specifying type WALL).
I have walls outside my air flow that have a temperature, and they transfer heat into the air. If you are trying this with natural convection only, and convection doesn't occur, you might not have gravity effects turned on. This would fail to create buoyancy and drive the convection. I'm pretty new at this - somebody correct me if I am wrong! |
mass flow in is not equal to mass flow out | saii | CFX | 12 | March 19, 2018 05:21 |
Constant velocity of the material | Sas | CFX | 15 | July 13, 2010 08:56 |
Convective / Conductive Heat Transfer in Hypersonic flows | enigma | Main CFD Forum | 2 | November 1, 2009 22:53 |
Convective Heat Transfer - Heat Exchanger | Mark | CFX | 6 | November 15, 2004 15:55 |
