convergence of energy
Old   February 10, 2005, 13:19
Default convergence of energy
Rajesh Kumar Tippabhotla
hi i am modelling a fuel cell ... 3 D geometry I have used a heat source term inside a porous volume. The trouble is that the solution is not converging for the order of the heat generation that i have given as input ( 9e9 W/m3)
After around 300 ierations, there is no significant change in energy residual, ( which starts at about 10e-4) and i get the results that i want, but if i continue the iterations till 5000 or more, the temp. keeps rising( and the solutions has stil not converged, residual keeps falling very slowly).
I have tried changing UR factors, but it does not make any difference. I await your suggestions. Thank you
Old   February 12, 2005, 12:39
Default Re: convergence of energy
cip
change the curent number and do a significant change of UR.
Convergence Centurion2011 FLUENT 48 June 14, 2022 23:29
Force can not converge colopolo CFX 13 October 4, 2011 22:03
SIMPLE and energy equation convergence Fabio Main CFD Forum 0 June 1, 2007 06:06
Convergence problem for P1 & Energy HP FLUENT 5 May 21, 2005 15:01
Energy equation convergence problem Reza Main CFD Forum 0 August 27, 2003 13:09
