gambit problem... help!!
Old   February 10, 2005, 22:48
Default gambit problem... help!!
Sham
I try to load a file in gambit to edit the model but this thing came out;
'Error:This database was not properly closed'
Can anyone help me with this. Thanks in advance.
Sham.
Old   February 11, 2005, 00:47
Default Re: gambit problem... help!!
Jason
What ever directory you saved the model in, there's a ####.lok file you have to delete where #### is the same as the filename of the model. Gambit deletes this file on a normal shut down... the idea is to prevent someone from opening the same model while you are working on it... if Gambit doesn't shut down properly, it doesn't delete the file and you'll have to do it manually.
Hope this helps, and goodluck, Jason
Old   February 11, 2005, 02:08
Sham
Thanks Jason,
I can't find the ###.lok file in my directory and I have deleted all the files with ###.lok just to avoid gambit crashes. Pls advise.
Sham.
Gambit geometry problem cestrin FLUENT 3 July 4, 2012 02:33
[Commercial meshers] Problem with Mesh conversion Gambit msh Foam Rachid BANNARI (Bannari) OpenFOAM Meshing & Mesh Conversion 25 September 11, 2011 07:58
Gambit installation problem Panos FLUENT 4 March 5, 2009 22:44
Problem meshing with Gambit Adrian FLUENT 8 October 7, 2008 08:39
Startup Problem in Gambit 2.2 with WindowXP Win Win Maw FLUENT 3 January 25, 2006 11:09
