Need help with gambit
Old   March 16, 2005, 18:01
Default Need help with gambit
ravi
I am using gambit and I'm new to it. I am trying to model a curved body with openings for flow to exit through it. I have some problem in creating the openings once I have the body geometry modelled. I need to split an arc at specified points so as to get the openings (which I later specify as inlet/outlet in the BC). Though gambit has provisions to split a line, there doesn't seem to be any such for splitting an arc. It does a 'virtual split'. But, this will pose other problems while creating the 'face'. Can anybody help/suggest me how can I overcome this problem and successfully split the arc at 2 pre-specified locations. Any help is appreciated.
thanks, ravi.
Old   March 16, 2005, 22:47
Default Re: Need help with gambit
Srinivas
use split the edge for arc it works for any edge like straight or curved...
Old   March 19, 2005, 17:00
ravi
Hi srinivas,
Thanks for the suggestion. It worked.
-ravi.
Converting Fluent mesh files to Gambit neutral files samuelkc ANSYS Meshing & Geometry 9 April 21, 2021 06:28
[GAMBIT] Canīt start GAMBIT zalho ANSYS Meshing & Geometry 18 April 8, 2019 01:05
Gambit help: Cube inside cube Jack Martinez FLUENT 13 August 11, 2010 06:29
Gambit 2.3.16, Xming or Exceed...HELP! bambam3417 FLUENT 10 May 7, 2010 12:39
Gambit -dev X11 doesn't work Ervin Amet FLUENT 0 October 28, 2007 08:33
