March 28, 2005, 09:27 |
not start gambit
this is the promption:
Cannot open connect stream. TRANS(SocketINETGetAddr): tnamebysocket() failed TRANS(SocketINETConnect): TRANS(SocketINETGetAddr) () failed TRANS(Open): transport open failed for tcp/LOCALPC:0 Unable to open display please help me to solve it thanks a lot. |
April 1, 2005, 03:22 |
Re: not start gambit
I had the same problem. but i got around it now... Not a nice solution but it works.
i start gambit with: cmd cd c:\fluent.inc\ntbin\ntx86 set display=:0.0 gambit -id pipe |
April 7, 2005, 23:34 |
have the same problem, but I tried your solution and the compurter says : system cannot find the path specified.
but everything else is working (Fluent) have any idea? thanks |
April 11, 2005, 09:01 |
I see that it is unclear that i am saying 4 commands. first one is to go to the "Dos" window:
cmd Then i go to the directory where fluent (gambit) is installed: cd c:\fluent.inc\ntbin\ntx86 The trick that works with me is: set display=:0.0 and then i start gambit with: gambit -id pipe |
November 14, 2009, 14:35 |
Sanket Ghatnekar
Rep Power: 16 |
Hi, hope you have succeeded in running gambit.?
If not please try the procedure below. I had xactly the same problem. It easily worked for me as per this procedure. (1) Start > Hummingbird Connectivity > Exceed > Exceed (Appln will open and u will see Exceed on task bar) (2) R-click (Exceed on task bar) > Tools > Session Startup > New (Untitled X-session window will open) (3) Click Directory.. > Select the folder where you have installed Gambit(generally the folder is Fluent.Inc) > Select gambit2.3.16 > OK (4) Click New Program > Select Windows App > OK (Untitled Wstart window will open) (5) Click Browse > Select Gambit ".exe" file > Select Run : Normal Mode > Run! (this will launch gambit application successfully) (6) Set the working directory in the application > Run (Gambit is launched / runs successful) Regards, Oxidising Agent (sanketssg@gmail.com) |
[GAMBIT] Canīt start GAMBIT | zalho | ANSYS Meshing & Geometry | 18 | April 8, 2019 01:05 |
gambit crashed | mbgnfrx2 | FLUENT | 1 | August 13, 2009 03:31 |
gambit start | Zhiqiang An | FLUENT | 2 | March 31, 2003 11:34 |
Generating big meshes with GAMBIT on NT | Andrew Ooi | FLUENT | 12 | February 2, 2000 22:26 |
Lets start the public domain CFD-Project! | Heinz Wilkening | Main CFD Forum | 3 | March 11, 1999 22:55 |
