f_in non premixed combustion
Old   April 20, 2005, 05:42
Default f_in non premixed combustion
abel
hello! I would have information on how interpreting graphs of species concentration in function of the mixture fraction (f), what does really "f" means?? is it a quantity defined for all the mixture (burnt, fresh) or for each species??
Old   April 20, 2005, 07:34
Default Re: f_in non premixed combustion
Ale
the mixture fraction is defined as f=(Y-Y_o)/(Y_f-Y_o), as reported also in the Fluent User's Guide. Y is, e.g., the mass fraction, 'o' indicates the oxidizer and 'f' the fuel.
It indicates the global composition of the mixture, it is 1 for the fuel stream and 0 for the oxidizer stream, and has a value between 0 and 1 where a mixture of the two streams is present.
I hope this helps.
Regards,
Ale
Modelling of premixed combustion in a burner rig ThomasS FLUENT 12 September 7, 2018 13:07
combustion model in premixed combustion chamber wuyu FLUENT 9 February 16, 2018 10:40
Non Premixed Combustion santhosh1987 FLUENT 3 January 2, 2017 10:42
Premixed Combustion IS FLUENT 3 July 9, 2010 20:22
Non-adiabatic Premixed combustion through scriptin Mahesh FLUENT 0 March 31, 2007 08:19
