June 2, 2005, 12:00 |
VOF variable contours
Hello there,
I'm trying to run a VOF animation sequence (this is my first VOF problem). I have two phases and have set the second at a value of '1' and the first phase at '0'. When viewing the animation sequences, instead of seeing a variable change in the displacment of the liquid over time, phase 1 remains at '0' and phase 2 remains constant at the '1' value. My question would be, how do i set the model to give me an animation of variable VOF contours so that i am able to look at the mixing / displacement of the liquid over time? very many thanks for any suggestions you can offer, thanks, gary. |
June 2, 2005, 13:41 |
Re: VOF variable contours
Are you sure you're solving that correctly? it might not be the postprocessing issue as you don't see any change in the variables. I would check out the boundary and initial conditions again to see if they are correct.
Cheers |
June 2, 2005, 13:47 |
Hello Amir.
Thanks for your reply. I'm a beginner with FLUENT so perhaps i am going wrong somewhere. I have a container with one inlet at the bottom and one outlet at the top. I am filling the container with fluid A from the inlet and then displacing fluid A, with Fluid B using the same inlet, forcing fluid A out of the outlet at the top. Fluids have the same density. I have tried following several tutorials which tell me to assign a volume fraction of '1' to the secondary phase (Fluid B in my case). Does this sound like the correct procedure to you? Thank you for your time and help! Gary. |
June 2, 2005, 14:24 |
You're welcome Gary, The procedure is correct. The volume fraction of fluid B should be set as 1 in the inlet boundary condition but be careful of that in initial condition. it should be set to zero when you initialize the case. I don't see any other point than that. I would recommend you to start off with Implicit VOF as it's easier to get convereged.
Amir |
June 2, 2005, 14:54 |
Hello again Amir,
Thanks for the reply but i'm a little confused. I can see where to set the value to '1' in the boundary conditions, but i don't understand what you mean by changing it to '0' when i initialize the problem. Is there a seperate window? or do i have to set the '1' value in the boundary conditions twice? If you have the time to explain the process, it would be greatly appreciated. thanks again, Gary. |
June 2, 2005, 15:24 |
ok sure, The boundary condition window appears in
Define -> Boundary Conditions but the Initial condition appears in Solve -> Initialize that's where you should set the Volume Fraction of fluid B to 0 as there's no B fluid in the tank when you start your simulation. Hope it helps Amir |
June 2, 2005, 17:33 |
thanks very much, i'll give it a try. gary
VOF & Variable Surface Tension in FLUENT | SeamusTCD | FLUENT | 13 | June 18, 2022 01:51 |
emag beta feature: charge density | charlotte | CFX | 4 | March 22, 2011 09:14 |
error in COMSOL:'ERROR:6164 Duplicate Variable' | bhushas | COMSOL | 1 | May 30, 2008 04:35 |
Env variable not set | gruber2 | OpenFOAM Installation | 5 | December 30, 2005 04:27 |
Replace periodic by inlet-outlet pair | lego | CFX | 3 | November 5, 2002 20:09 |
