Source Term
Old   June 5, 2005, 05:42
Default Source Term
Murthy
Hi, I am simulating Multipahse Stirred Vessel using fluent6.x. I have not explicitly created sparger in the geometry to sparg gas so i want to specify gas input as a source term.I know how to do it in fluent 4.4 but not sure how to specify in fluent 6.x. I would appreciate if some one could help me out in this regard.
Regards Murthy
Old   June 6, 2005, 10:34
Default Re: Source Term
Alec Eiffel
you need to define the cell for sparger as a different zone using gambit. Then in the boundary conditions for that zone you can define a mass and momentum source
have a look at section 7.28 in fluent help files
Old   June 7, 2005, 00:11
Murthy
Hi Alec,
Thanks for ur reply. I would try it. Murthy
momentum source term zwdi FLUENT 14 June 27, 2017 15:40
[swak4Foam] swak4foam building problem GGerber OpenFOAM Community Contributions 54 April 24, 2015 16:02
DxFoam reader update hjasak OpenFOAM Post-Processing 69 April 24, 2008 01:24
DecomposePar links against liblamso0 with OpenMPI jens_klostermann OpenFOAM Bugs 11 June 28, 2007 17:51
UDFs for Scalar Eqn - Fluid/Solid HT Greg Perkins FLUENT 0 October 13, 2000 23:03
