Dynamic Mesh setup problem
Old   June 7, 2005, 06:50
Default Dynamic Mesh setup problem
Jim
Hi all, I am trying to set up a simple dynamic mesh problem. I want to model a 2D pipe in which a zone at the inlet moves upwards, which effectively closes the inlet of the pipe after a set time. I am using the in-cylinder model and I have prescribed identical rigid body motion for the walls and grid of the moving area and specified an interface between the moving and non moving zones. When I try to solve the mesh motion it Fluent gives me the follow message Error: Compute-node-normal: Degenerate faces. Can someone please advise me on the correct way to set up the problem. Thanks in advance, jim
Old   June 8, 2005, 09:26
Default Re: Dynamic Mesh setup problem
Evandro
What dynamic mesh model (layering, smoothing , remeshing) do you use? I think you don't have prescribe motion for grid, just for walls.
3D Hybrid Mesh Errors DarrenC ANSYS Meshing & Geometry 11 August 5, 2013 06:42
[Gmsh] 2D Mesh Generation Tutorial for GMSH aeroslacker OpenFOAM Meshing & Mesh Conversion 12 January 19, 2012 03:52
CFD-3D flow problem using Dynamic mesh method. Sar_mech FLUENT 1 November 27, 2008 21:17
Problem with Dynamic Mesh and Fluent Claude Main CFD Forum 0 December 12, 2006 06:03
Dynamic mesh problem Sampath FLUENT 1 October 13, 2004 06:44
