Graphic Problem with ATI Radeon 9600 / 9700
Old   June 8, 2005, 09:07
Default Graphic Problem with ATI Radeon 9600 / 9700
peter hess
hallo, after I installed FLUENT on my LABTOP, I discovered, that there is no compatipility between my Graphic Card and the Program (FLUENT). actually, I can start the Program and do the Pre-Processing and the Solution without any Problem. but wenn I start the Post-Processing and want to open the Graphics Window, I get a white Secreen and an Erorr in Fluent "Error: Floatin Point error: divide by zero". "Error object)"
thanks
Peter
P.S. I got the same Problem with my desktop. I changed the Graphic Card with another one from NVIDIA and it worked.
Old   June 8, 2005, 09:42
Default Re: Graphic Problem with ATI Radeon 9600 / 9700
peter hess
Thanks it worked! Peter
Problem with viewing graphic view when running in UNIX pitisrisuk Main CFD Forum 1 April 15, 2016 11:39
Gambit - meshing over airfoil wrapping (?) problem JFDC FLUENT 1 July 11, 2011 05:59
graphic problem chiccopeso CFX 8 June 7, 2010 07:18
I have a problem with GridgenV15 graphic display Carlo ANSYS Meshing & Geometry 1 April 11, 2009 14:33
Graphic Problem with ATI Radeon 9600 / 9700 Kamenos Xanthi FLUENT 2 February 26, 2007 10:51
