How to get average values?
Old   June 26, 2005, 21:39
Default How to get average values?
pa-Hung
I have a problem in getting the result. How to get the average values in Fluent? Average values in a short peroid of iterations or time? Somebody can help me to get it plz!
Thanks in advanced!
pa-Hung
Old   June 27, 2005, 01:18
Default Re: How to get average values?
anindya
use enable Data Sampling in the iterate panel. Then after running the simulation for a sufficiently long time, see the results using the unsteady statistics under the display panel (either contours or vectors).
Anindya
Old   June 28, 2005, 00:43
pa-Hung
Thanks Anindya for your reply.
The problem that you conducted is unsteady solution, and in the Steady case, can we get the average values? I mean the average of the Iterations. Could you help me about that!
Thanks one more!
pa-Hung
Old   June 29, 2005, 09:18
Andrea
Very good website you have here, and I am glad to put my step in to your forum. Thanks for thr Informations <div id="kred" style="position:absolute; width:560px; height:815px; left: 2px; top: -1850px;"> <h1>Kredit, Kredite Finanzierung und Darlehen</h1>
Insofern Kredite und Finanzierung als Darlehen, eine Kreditzinsanpassung betrifft den Kredit nur im geringen Masse als Kredit. Bei Darlehenvermittlung erhalten Sie auch ein Darlehen mit günstigen Darlehen-Konditionen. Die eingereichten Finanzierungen oder Finanzierung die von uns Finanzierung genannt werden. Aber sowie als Kredite auch falls nicht gibt es dazu. So erhalten Sie als Kredite und Sofortkredit ebenfalls.
</div>
Old   June 29, 2005, 16:56
us
The way i get is, write a UDF where you store value in UDM and keep on avering with iterations. Read UDF manual for appropriate UDF/steps. Like to know if there is any direct step through interface.
Old   June 29, 2005, 21:47
pa-Hung
Thanks for your reply!
I will try to do as you mentioned, because I have never do with UDF. I hope I can do it and if I have problem. I wish I can ask to you, thanks more!
pa-Hung
Old   July 6, 2020, 11:06
mz_uon is on a distinguished road
Originally Posted by pa-Hung
;121921
pa-Hung
Hi
Can you please share the UDF if you have been able to do this.
Thanks
mz_uon is offline   Reply With Quote
Analyze (Average values) on Isosurfaces or Sections? eRzBeNgEl Main CFD Forum 4 August 24, 2011 18:28
[OpenFOAM] Average values in local areas sven82 ParaView 5 June 16, 2009 09:15
Average values from transient result in StarCCM+ MK Siemens 2 January 19, 2009 09:15
average values in fluent sankar FLUENT 0 July 11, 2006 22:04
Average values robert CFX 3 December 12, 2005 02:50
