Nodes Vs Quality?
Old   June 28, 2005, 11:14
Default Nodes Vs Quality?
Gary Holland
Hello there,
I'm quite new to fluent and have a question regarding the node spacing. When i run a simulation with a certain node spacing, i get a result. Ok. Now, when i increase the node spacing and run the simulation again, i get a different result and the calculations take longer. So, does this mean that the more nodes I have, the more reliable and realistic the result???
Many thanks for any suggestions, Gary.
Old   June 28, 2005, 11:29
Default Re: Nodes Vs Quality?
AJG
Gary,
The number of nodes has a relation with the accuracy of the result, however if you have too many! nodes you might cause your simulation to be unstable. What people usually do is a grid dependance study where you run your simulation with a very coarse grid and keep increasing the number of nodes (or minimizing the spacing) until a point where the solution don't change anymore and thats the number of nodes recommendable.
hope this help,
AJG
Old   June 28, 2005, 11:51
Gary Holland
Very many thanks, I'll take that into account and try again. gary.
SIMPLE algorithm SamR Main CFD Forum 19 April 26, 2019 13:06
Scale-Up Study in Parallel Processing with OpenFoam sahm OpenFOAM 10 April 26, 2010 17:37
[ICEM] Hex refinement negative quality afterwards Anorky ANSYS Meshing & Geometry 8 March 22, 2010 03:25
meshing F1 front wing Steve FLUENT 0 April 17, 2003 12:37
CFX4.3 -build analysis form Chie Min CFX 5 July 12, 2001 23:19
