Gridgen and reversed flow.
Old   July 5, 2005, 22:36
Default Gridgen and reversed flow.
pah
Hi Everybody!
I used Gridgen to generate the grid system for solver is Fluent. When I use the minimum spacing is 10e-04, the Solver running without warning about "reversed flow", But when I reduce the minimum spacing size to 10e-5, in the same solving condition, the reversed flow warning appears.
So, could you show to me what is prolem and what I should do? I'm sorry if it is stupid question, but hoping your recommendation.
Thanks in advanced! pah
Old   July 8, 2005, 06:00
Default Re: Gridgen and reversed flow.
K. Jagus
I also use Gridgen. DO You have the reversed flow only at the beginning? I think it is pretty common to receive this warning at the beginning, usually it disappears after few iterations
Old   July 8, 2005, 11:10
pah
Yes, K. Jagus!
Sometime, I met the situation like you said,but sometime it do not disappear and the solution is stopped due to overflow or some others warning. So, I am confusing about this problem, somebody can help plz! Thanks a lot
pah
Negative Volume in Mesh by Gridgen James FLUENT 5 February 3, 2010 07:34
