Location of interface for sliding mesh
Old   July 13, 2005, 03:31
Default Location of interface for sliding mesh
Gopal
hi I am trying to solve the flow in a stirred tank with rushton turbine. I have got good results with MRF but now i want to solve it with Sliding Mesh. Can i use the same inner and ourter zones of MRF for sliding mesh or i have to change the location of the interfaces.
gopal
Old   July 14, 2005, 04:30
Default Re: Location of interface for sliding mesh
Razvan
No, but you have to be sure that the interfaces are surfaces of revolution and defined on practically identical geometries, otherwise you will not get a converged solution. And of course, change "Moving Reference Frame" to "Moving Mesh", but you must know that already.
Best wishes, Razvan
[ICEM] surface mesh merging problem everest ANSYS Meshing & Geometry 44 April 14, 2016 06:41
Spontaneous failure of moving mesh interface gareth__it_power ANSYS 1 August 26, 2010 07:50
RPM in Wind Turbine Pankaj CFX 9 November 23, 2009 04:05
increasing mesh quality is leading to poor convergence tippo CFX 2 May 5, 2009 10:55
Icemcfd 11: Loss of mesh from surface mesh option? Joe CFX 2 March 26, 2007 18:10
