Dear all,
I'm facing a little trouble. I've already specify the interfaces boundary types at Gambit. And then, when i defined "Grid Interfaces" at FLUENT, it can't works. There's an error at the fluent window, it was written like this "Error: Poly triangulate". What is the meaning of that? And how should i do to solve that error? Thank you very much for your response. Regards Ridwan |
the reason could be creating interface between a very large surface and a small surface...in that case, divide large surface into small surfaces and then use grid interface..
the reason may be surfaces are not co-planer...it happens partculary if you do in virtual operation in gambit... Dipak |
Grid Interfaces | soggy316 | FLUENT | 12 | May 17, 2012 05:17 |
B.C and Grid size LES Fluent | vishwa | Main CFD Forum | 0 | April 16, 2009 13:08 |
Grid for Fluent v.4 using Gambit? | Ray | Main CFD Forum | 3 | October 27, 1999 12:35 |
How to do Grid Generation for the FLUENT? | timea | Main CFD Forum | 2 | April 7, 1999 09:03 |
Do you have the experience about pressure oscillations at grid interfaces? | Hansong Tang | Main CFD Forum | 7 | February 22, 1999 14:48 |
