Simulating a solid spinning disk in IcePak
Old   July 28, 2005, 18:39
Default Simulating a solid spinning disk in IcePak
Akash
Could anybody guide me as to how I could implement a rotating disk in IcePak?
Thanks, Akash
Old   July 29, 2005, 12:13
Default Re: Simulating a solid spinning disk in IcePak
manohar
hi akash,
can u explain us little more clearly. i mean, do u need the solid domain inside? normally what the CFD people will do if there no analysis is going to do on the solid is "places a void in place of the solid". and regarding rotation, just simply give the walls as the rotating walls.
Old   July 30, 2005, 16:07
Akash
Hello Manohar,
Thanks for your response. I have an enclosure with some heat sources and a spindle motor on which a disk is mounted. The disc spins with a certain angular velocity. As the spinning disk will move the air around it and hence cause a difference in the heat transfer effectiveness, I would need to simulate a spinning disc inside the enclosure too. In IcePak, can I just create a wall,calculate the linear velocity from the angular velocity and then specify that value as components in the X, Y and Z directions? Any suggestions will be really appreciated.
Regards, Akash
Old   July 31, 2005, 02:00
manohar
hi akash,
i think for ur case if the disk is fully solid (means, there is no holes or vanes in the disk) u can just define the wall as rotating. that is sufficient. i dont know exactly but as of my knowledge we can't rotate the solid domain (almost i tried for one month but i didn't get for my case). for anything else i am ready to help u.
Old   August 1, 2005, 11:21
Akash
I got in touch with IcePak tehc support. They say that the new version of IcePak--4.2 has the capability to support a spinning disc.Thanks so much for all your assistance Manohar.
Regards, Akash
Multiple Solid Domains - Interfaces Scott CFX 8 July 31, 2008 15:20
liquid film thickness over spinning disk fadhil FLUENT 0 May 28, 2008 07:10
spinning disk zahed FLUENT 0 March 6, 2008 12:01
Flotherm-Icepak comparison for electronic cooling Masoud Ameli FLUENT 0 February 28, 2005 09:00
