August 1, 2005, 23:28 |
negative heat transfer coeffecient
hello all, I am trying to simulate natural convection over a vertical plate, but i am getting a negative surface heat transfer coeffecient. why is this?
August 2, 2005, 00:26 |
Re: negative heat transfer coeffecient
heat transfer coefficient will be calculated by using heat flux divided by the temperature diff which is equal to (Twall - Treference). if ur Treference is greater than Twall u get a negetive h. check for the reference values and see if ur plate is g etting heated up or is it getting cooled....
August 3, 2005, 21:57 |
Thanx rajani,
Inspite of having my wall temperature greater than the reference temp value the heat tranfer coefficient values are negative. I obained negative heat transfer coeffecient for pr = 0.72 and the temperatures being below 0 degrees celcius (wall temp = 257K (-16C), air temp = 247 (-26C)) however for temperatures in the region of 900K, where pr = 0.72 (from internet), I obtained positive heat transfer coeffecients, but some how my results dont appear to correlate properly with the theoritical results. I need to know the exact thermal properties based on prandtl number for pr = 0.69 and pr = 0.72. Unfortunately, i browsed the internet as well as many books but founds different answers. Can any of you give the thermal properties of air at pr=0.72.I need air temp,desity, thermal conductivity,viscosity and specific heat properties. regards Sireesha Pasari |
August 3, 2005, 23:19 |
try Perry's Chemical Engineers' Handbook. you should look at it carefully though. it is the properties that will decide Pr value and not vice versa and there are three of them involved in its definition. for all substances, you will find properties as a function of temperature.
Swarup |
[blockMesh] BlockMesh FOAM warning | gaottino | OpenFOAM Meshing & Mesh Conversion | 7 | July 19, 2010 14:11 |
Convective / Conductive Heat Transfer in Hypersonic flows | enigma | Main CFD Forum | 2 | November 1, 2009 22:53 |
[blockMesh] Axisymmetrical mesh | Rasmus Gjesing (Gjesing) | OpenFOAM Meshing & Mesh Conversion | 10 | April 2, 2007 14:00 |
negative heat transfer coefficient | Sigrid Andreae | CFX | 1 | February 26, 2005 07:13 |
