August 4, 2005, 05:18 |
need some suggestion
hi i am doing internal flow through of intake of turbocharge engine of 0.6 mach speed to calculate force on wall at bend.i am using coupled solver with 1 CFL no and inviscid flow.the soltion is not converging at high spped flow .can anybody tell me what i should do nabeel
August 4, 2005, 07:11 |
Re: need some suggestion
At first sight: decrease your CFL (at least at startup). By the way: is the solver explicit or implicit?
Cheers Edi. |
August 9, 2005, 18:12 |
why inviscid flow for an internal calculation? Why coupled solver? Did the segregated solver mess up?
anyway, good luck, Laika, still orbiting |
August 10, 2005, 02:39 |
hi, coupled solver is used because seed is 180m/s and implict is being used i reduced CFL 0.001 to 1 but not converged second question answer flow is high speed so inviscid is used and 1 equation model is preferred. my target is to calaculate the pressure force on a area at bend of turbo jet waiting for your response
August 10, 2005, 18:02 |
Have you tried to simulate using the segregated solver and a high Re turbulence model yet?
August 18, 2005, 03:55 |
hi i have used segregated solver but with momentum power law solution controls and simplec pressure velocity coupling but not have good result i used 1 equation because of high speed flow any suggestion nabeel
August 22, 2005, 06:55 |
hi i have tried pressure far field but no avail i vannot attain velovity more that 100m/s even map meshing .can any boddddddddy help !!!!!!!!!!!!!!!!!! nabeel
August 23, 2005, 04:45 |
hi i have tried skw turbuolence model but it was not diveging and with SA model it was converged till 100 m/s any helppppppppppp nabeel
suggestion for thermophysicalproperties for high temperature buoyant flow | braennstroem | OpenFOAM Running, Solving & CFD | 0 | March 21, 2011 14:06 |
any suggestion about method to use? | cnmm | Main CFD Forum | 0 | May 28, 2009 23:13 |
Suggestion to make spray simulations more stable | fabianpk | OpenFOAM | 4 | October 16, 2007 06:53 |
To webmaster or forum modulator: a suggestion | ma | Main CFD Forum | 16 | December 11, 2004 10:56 |
can you give me some suggestion? | reck | Main CFD Forum | 0 | November 25, 2001 00:40 |
