turbulence specification at inlet
Old   August 15, 2005, 20:12
Default turbulence specification at inlet
ziya
Does anybody have an idea how sensitive the turbulence models in Fluent are to the turbulence values at the inlet? Is it just used as a boundary condition to initialise the solution? I am currently validating an experiment about sails where the oncoming flow has a fine scale turbulence. I am using k-w sst.
Cheers,
Ziya
Old   August 16, 2005, 01:24
Default Re: turbulence specification at inlet
razvan
As all turbulence models based on k-e model, sst-kw is not very sensitive to inlet values. However, pay attention that Fluent is using user inlet values for turbulence quantities (whichever way you decide to specify them) into calculations!!
In your particular case, I think is better to use a combination of turbulence intensity + turb. lenght scale or turb. viscosity ratio.
Best wishes, Razvan
Turbulence length scale and integral length scale rizhang CFX 2 April 22, 2016 07:22
Default inlet turbulence for LES N Barton CFX 11 July 24, 2015 00:34
Species mass flow inlet lorenz FLUENT 3 March 15, 2012 07:26
Mass Flow Inlet with Velocity specification bernarde STAR-CCM+ 1 December 3, 2009 23:13
Inlet : Turbulence Specification Method PK FLUENT 0 February 2, 2006 10:40
