UDS Flux Function Problem
Like Tree1Likes
  • 1 Post By NTSbike
Old   July 10, 2012, 11:43
Default UDS Flux Function Problem
Jun Li
sunbird04 is on a distinguished road
Hey all,
Recently I want to use Fluent's user define scalars(uds) to solve the nucleation of equiax grain in a ingot cast problem with Fluent Eulerian Mutiphase Model. The control equation for the nucleation of equiaxed grain as follow:
N/t+(uN)=source
Therefor, for both the Unsteady Function and Flux Function should be defined by udf. My code is shown:
DEFINE_UDS_UNSTEADY(unsteady_terms,cell_index,cell _thread,i,apu,su)
real cell_volume, physical_dt, RHO_cell, vof, vof_new, phi_old;
cell_volume = C_VOLUME(cell_index,cell_thread);
physical_dt = RP_Get_Real("physical-time-step");
RHO_cell = C_R(cell_index,cell_thread);
vof = C_VOF_M1(cell_index,cell_thread);
vof_new = C_VOF(cell_index,cell_thread);
/* IMPLICIT PART OF THE TIME DERIVATIVE DISCRETIZATION */
*apu = -(cell_volume)/physical_dt;
/* EXPLICIT PART OF THE TIME DERIVATIVE DISCRETIZATION */
phi_old = C_STORAGE_R(cell_index,cell_thread,SV_UDSI_M1(i));
*su = (cell_volume*phi_old)/physical_dt;
/* CONVECTIVE (FLUX) TERMS */
DEFINE_UDS_FLUX(convective_flux_terms,face_index,f ace_thread,i)
Thread *t0, *t1 = NULL;
cell_t c0, c1 = -1;
real NV_VEC(psi_vec), NV_VEC(A), vof, flux = 0.0, rho = 2;
c0 = F_C0(face_index,face_thread);
t0 = F_C0_THREAD(face_index,face_thread);
vof = C_VOF(c0, t0);
/* if(PRINCIPAL_FACE_P(face_index,face_thread)) */
F_AREA(A,face_index,face_thread); /* NORMAL VECTOR OF THE FACE */
if(BOUNDARY_FACE_THREAD_P(face_thread))
NV_DS(psi_vec,=,F_U(face_index,face_thread),F_V(fa ce_index,face_thread),F_W(face_index,face_thread), *,1.0);
flux = NV_DOT(psi_vec,A); /* FLUX THROUGH THE FACE */
else
c1 = F_C1(face_index,face_thread);
t1 = F_C1_THREAD(face_index,face_thread);
NV_DS(psi_vec, =,C_U(c0,t0),C_V(c0,t0),C_W(c0,t0),*,1.0);
NV_DS(psi_vec,+=,C_U(c1,t1),C_V(c1,t1),C_W(c1,t1), *,1.0);
flux = NV_DOT(psi_vec,A)/2.0; /* AVERAGE FLUX THROUGH THE FACE */
return (flux);
Only momentum equation is solved. For these code I done two different cases:
Case I, only the melt (liquid) region is considered. For this case the simulation result is reasonable;
Case II, both the melt (liquid) and model (solid) are considered which means this is a liquid solid couple problem. For this case, the simulation cannot running. The error message emerged even at the first iteration:
Error:
FLUENT received fatal signal (ACCESS_VIOLATION)
1. Note exact events leading to error.
2. Save case/data under new name.
3. Exit program and restart to continue.
4. Report error to your distributor.
Error Object: ()
I'd appreciate your help. Thanks in advance.
sunbird04 is offline   Reply With Quote
Old   July 11, 2012, 02:54
Jun Li
Old   July 11, 2012, 13:14
Jun Li
Old   July 11, 2012, 13:15
Jun Li
Please help me!
Old   July 13, 2012, 04:29
Jun Li
Old   September 19, 2013, 05:13
Georgy
gera is on a distinguished road
sunbird04,
Did you use Windows?
I often see such message on the Windows OS.
It looks like on the Linux OS, this error message appears less frequently.
gera is offline   Reply With Quote
Old   April 28, 2014, 02:58
Tsaba Nagy
NTSbike is on a distinguished road
This message is usually for a UDM number problem (for example). If you have 5 UDM-s in your UDF, but in the Fluent only 4 is set, you will have this error message. The UDF and UDS numbers are started with zero, so if your last UDM is "C_UDMI(c,t,4)", you have 5 UDMs. Check all the setups. Usually you can see the name of the desired UDF, which is providing the error.
Demian16 likes this.
NTSbike is offline   Reply With Quote
UDS Flux Function Choice Yang Chung FLUENT 1 November 17, 2015 01:14
Problem with function Compute_Force_And_Moment zedas FLUENT 1 October 15, 2012 00:36
OpenFOAM static build on Cray XT5 asaijo OpenFOAM Installation 9 April 6, 2011 12:21
Help with UDS FLUX Andrew Garrard FLUENT 2 February 14, 2005 05:47
ODD: no UDS flux across interior boundary Bob FLUENT 1 February 25, 2002 19:15
