Error: Dynamic-Mesh failed. -ve cell vol Detected
Old   August 26, 2005, 08:01
Default Error: Dynamic-Mesh failed. -ve cell vol Detected
Manoj Kumar
Hi everyone
I am trying to simulate heave motion of a ship using dynamic meshing. I have used a udf to define regid body motion of the ship and I have assigned the fluid zone as deforming.
I am getting follow error ..
WARNING: non-positive volumes exist.
Error: Update-Dynamic-Mesh failed. Negative cell volume detected.
Error Object: ()
I tried smoothing the mesh, which does helps for a while. But the error repeats again and again.
Please help me.
Thanks
Manoj
Old   August 26, 2005, 08:06
Default Re: Error: Dynamic-Mesh failed. -ve cell vol Detec
Mario
Run grid => check. It seems you have negative volumes. If grid check failed you have to maintain the grid. Try to locate the negative volumes in gambit and remesh those areas.
Old   April 27, 2014, 17:04
kozalp is on a distinguished road
Hi everyone,
I am trying to simulate a piston motion in a lateral cylinder.
I defined a piston profile and profile simply consists of time-location data, such as:
(time
0
0.05
0.1
0.15
0.2
0.25
0.3
0.35
0.4
0.45
0.5
0.55
0.6
0.65
0.7
0.75
0.8
0.85
0.9
0.95
1
(x
1.2
1.225
1.25
1.275
1.275
1.275
1.275
1.275
1.275
1.275
1.275
1.275
1.275
1.275
1.275
1.275
1.275
1.275
1.275
1.275
1.275
When I give a constant move to the piston, I can solve the case; but when I define a profile like the above one, it gives negative cell volume error. It gives error when I give a periodic piston motion too. With periodicity what I mean is that piston moves-stops and moves again periodically. There is no oscillating motion.
What might be the problem. The case looks simple but I cannot solve it. By the way, my mesh consists of quad meshes and the case is 2D.
kozalp is offline   Reply With Quote
3D Hybrid Mesh Errors DarrenC ANSYS Meshing & Geometry 11 August 5, 2013 06:42
[ICEM] Generating Mesh for STL Car in Windtunnel Simulation tommymoose ANSYS Meshing & Geometry 48 April 15, 2013 04:24
[ICEM] Hugh cell jump in Tetra mesh jeevankumarb ANSYS Meshing & Geometry 3 June 2, 2010 10:45
Convergence moving mesh lr103476 OpenFOAM Running, Solving & CFD 30 November 19, 2007 14:09
unstructured vs. structured grids Frank Muldoon Main CFD Forum 1 January 5, 1999 10:09
