lift & drag coefficient on airfoil
Old   August 29, 2005, 05:39
Default lift & drag coefficient on airfoil
n. natik
dear sirs how can i calculate the lift & drag coefficient on airfoil surface for 2-d incompressible case, for fluent post processing i can calculate and draw only cp(pressure coefficient), what about lift & drag coefficient ?? thanks in advance for your early replay
Old   August 29, 2005, 06:26
Default Re: lift & drag coefficient on airfoil
Jason
You can monitor lift & drag coefficients while your solution iterates by going to Solve->Monitors->Forces. In fact, if in your final results you want the lift & drag coefficient, then you should monitor them to ensure convergence.
Once you have a final solution you can get forces and moments from Report->Forces. It will print the force (or moment) in your units and in coefficient terms.
Make sure you've defined your reference values at Report->Reference values. A sticking point is that "length" is the reference length used in the moment coefficient (Cm = 1/2*Rho*V^2*Aref*Lref) while "depth" is the length of your model in the z direction. If you set "depth" to 1, then it's a per unit length setup.
Hope this helps, and good luck, Jason
Old   October 23, 2009, 01:59
Default dear sir..
vivit
vivit apriliyanti is on a distinguished road
Can you tell me?? What is the Basic Calculation of FLUENT on Computing Lift Coef In Modelling 2D??
thanks
vivit apriliyanti is offline   Reply With Quote
Old   October 23, 2009, 18:38
Talking
teguhtf's Avatar
teguh hady
teguhtf is on a distinguished road
Hy vivit apriliyanti!!
My problem is same as yours!! I think that 2d airfoil don't have A!!! So if A equal to 0 then Cl will be infinite!!! But when we run FLUNT 2D we'll see VOLUME after check our grid!!! the value of volume is not zero!! I think the value of Cl is based on that volume!!
hope it helps!!
teguhtf
teguhtf is offline   Reply With Quote
Old   December 7, 2009, 06:25
Default hello mister
vivit
wahat is grid independensi in FLUENT? please you explain,thnks
Old   December 16, 2009, 07:22
Default Basic Computation Of 2D
teguhtf's Avatar
teguh hady
Sorry, for waiting. After searching in some books, I've opinion that For solving Cl & Cd in 2D. There is assumption that the value of A is 1. you can read this on Anderson Computational Fluid Mechanics And Heat Transfer.
Hope it helps
teguhtf
Now Or Never!!!
Old   December 16, 2009, 10:14
JT.Q
jiangtao167 is on a distinguished road
Originally Posted by n. natik
;123784
1、for a 2d case,take x-y plan for example, the length in z direction is 1, so A=L(m)*1=L(m)
2、in force report panal, you can set the force vector to obtain cd and cl respectively.set x=1 and y=0,you will get cd,if x is the velocity direction.set y=1 and x=0, you will get cl.
jiangtao167 is offline   Reply With Quote
Old   December 17, 2009, 08:30
aescarbi is on a distinguished road
Grid independence means that your solution does not change appreciately when you refine your mesh.
aescarbi is offline   Reply With Quote
Old   March 31, 2015, 19:02
Exkalabur22 is on a distinguished road
Originally Posted by Jason
;123785
Hello
I am simulating the flow over a 2 element airfoil which is to say that there is a main wing and a flap. I want all coefficients to be scaled to a unit chord. I am unsure whether FLUENT uses the real length of the airfoil or the reference length. I calculate both the lift and drag coefficient on the main, flap and both. However only the main wing and flap combined chord is 1m.
I am not quite clear from your explanation what whether FLUENT is assuming a unit chord for all calculations of CL and CD regardless of actual size or if it assumes the actual size. Depth is the z direction or the span of the wing and the length is used for moment how do I define a unit chord? is it in the area value?
Thanks in advance for the help.
Exkalabur22 is offline   Reply With Quote
Lift and Drag Coefficient data for NACA 2412 Airfoil mahbub03 Main CFD Forum 22 May 25, 2014 15:39
Lift and drag coefficient with strange values for NACA airfoil antonio_ing OpenFOAM Running, Solving & CFD 16 September 13, 2012 12:21
Fluent Good Lift coefficient BAD drag coefficient Rif Main CFD Forum 4 March 9, 2010 10:52
Automotive test case vinz OpenFOAM Running, Solving & CFD 98 October 27, 2008 08:43
drag and lift coefficient Noé Siemens 5 July 13, 2004 10:21
