natural convection
Old   September 18, 2005, 14:06
Default natural convection
rachid
Hi I am working on simulating the basic natural convection in 2-D. There is a small rectangle (hot brick at constant temperature) and there is the large rectangle (flow field). I have given the temperatures for the brick and two side walls on the outer rect. In the tutorial n.5 they say we can model this similar flow with turning off the radiation model. Which boundary conditions the top and bottom edges should have?
I tried wall BC's for the outer rect. and no flow happened. After that i tried p out and p in but the flow in this case occured from the pressure difference
What is the correct BCs?
Old   September 19, 2005, 16:42
Default Re: natural convection
Evan Rosenbaum
Wall BCs should work. You did specify a temperature-dependent fluid density somehow (i.e., ideal gas, Boussinesq, etc.), right?
Old   September 20, 2005, 10:21
rachid
No i haven't. I suppose you mean the materials panel (Boussinesq) because the radiation model is off.
This makes sense though thank you so much... So how do I do that? I mean specyfying a temperature-dependent fluid density. Is there any literature or fluent tutorial you can advise?
Old   September 20, 2005, 11:04
rachid
I found out that thermal expansion coefficient parameter which is available with the boussinesq type density is the key.
My new question is: Is it right to define a constant thermal expansion coefficient while it is temperature dependent? (3.47*e-3 K-1)
Old   September 20, 2005, 12:25
Evan Rosenbaum
If you use Boussinesq and if temperatures don't vary too much you can use a constant expansion coefficient. Don't forget to set gravity too.
Old   September 20, 2005, 14:43
rachid
Thank you Evan Rosenbaum. It works!!!
natural convection problem with radiation jorien CFX 0 October 14, 2011 09:26
Natural Convection with heat generation krishnachandranr Main CFD Forum 0 July 28, 2009 04:22
Coupled vs Seg - Natural vs. Forced Convection Alex Siemens 5 December 12, 2007 04:58
natural convection at high Rayleigh mauricio FLUENT 2 February 23, 2005 19:43
Mixing By Natural Convection Processes Greg Perkins FLUENT 0 February 12, 2003 18:40
