heat transfer
Old   September 28, 2005, 03:48
Default heat transfer
enzo
I want to study the heat transfer in solid and fluid.I defined the interface between solid and fluid as wall and Fluent created a shadow wall.I defined wall and shadow wall "coupled" but in the solid the temperature profile is only horizontal.Why?Where is the error?Can someone help me?And Fluent can study heat transfer in solid or only for fluid? Thanks
Old   October 5, 2005, 12:17
Default Re: heat transfer
R
You need to define the solid as a zone (while creating geometry in Gambit), then specify its boundaries as walls. You need to pick a material for this solid zone, and specify boundary conditions, e.g. fluiid-solid interface as coupled and solid-air interface as convenctive. Hope this helps.
-R
Two-sided Wall Heat Transfer BC - No Separate Solid Mesh and No Heat Transfer Coeff swahono OpenFOAM Running, Solving & CFD 10 October 15, 2018 05:43
Convective / Conductive Heat Transfer in Hypersonic flows enigma Main CFD Forum 2 November 1, 2009 22:53
How can I increase Heat Transfer at Domain Interf? B.Simon CFX 3 October 28, 2008 18:53
Convective Heat Transfer - Heat Exchanger Mark CFX 6 November 15, 2004 15:55
