gambit non-planar trim
Old   October 7, 2005, 15:00
Default gambit non-planar trim
ahmet
Hi everybody;
I am new with gambit and fluent. I need to trim one side of a surface which intersects with another surface that is drawn in a different plane. Could you please help me with this?
Thank you all.
ahmet
Old   October 10, 2005, 09:03
Default Re: gambit non-planar trim
Jason
I think the command you're looking for is the split command. In the Face Geometry commands, its in the second row, second icon from the left. You can split the first surface with the second. This will split the first surface into two pieces and you can delete the piece you don't want.
Hope this helps, and good luck, Jason
Old   October 16, 2005, 17:47
ahmet
thanks jason, it worked pretty well.
ahmet
Converting Fluent mesh files to Gambit neutral files samuelkc ANSYS Meshing & Geometry 9 April 21, 2021 06:28
Gambit help: Cube inside cube Jack Martinez FLUENT 13 August 11, 2010 06:29
Gambit 2.3.16, Xming or Exceed...HELP! bambam3417 FLUENT 10 May 7, 2010 12:39
Gambit -dev X11 doesn't work Ervin Amet FLUENT 0 October 28, 2007 08:33
GAMBIT and Turbomachinery tom Main CFD Forum 6 October 21, 1999 09:50
