Temperature specifications
Old   October 20, 2005, 20:32
Default Temperature specifications
Vidya Raja
I have a 2d mixing elbow. The geometry and dimensions are exactly those of that given in the GAMBIT tutorial. Now I have 2 streams of water (373K and 273K) at the two inlets. Both are at the same flowrates. How do I specify the temperatures in FLUENT? Which command do I use? The flow is laminar and incompressible.
Thanks in advance.
Vidya
Old   October 24, 2005, 01:30
Default Re: Temperature specifications
RoM
Enable energy equation (define->models->energy) and define the temperature in the boundary conditions.
RoM
Problem with zeroGradient wall BC for temperature - Total temperature loss cboss OpenFOAM 12 October 1, 2018 06:36
Calculation of the Governing Equations Mihail CFX 7 September 7, 2014 06:27
Bulk temperature Tf is obtained from total or static temperature? NPU_conanxie FLUENT 0 March 30, 2011 05:56
Different patch type specifications for velocity and temperature ankgupta8um OpenFOAM Running, Solving & CFD 5 December 31, 2010 10:57
High temperature methane+air Peter FLUENT 5 January 26, 2009 18:04
