loading new mesh in converged solution
Old   November 4, 2005, 02:49
Default loading new mesh in converged solution
Claudia
Hello, how can i load a very similar mesh while using an almost converged solution? I only changed one diameter while keeping the rest. How can i load the new mesh in? When I use file --> read --> case --> ...msh then the iteration starts all over. Can anyone help me! Thanx. Claudia
Old   November 4, 2005, 05:23
Default Re: loading new mesh in converged solution
RoM
To use a converged solution on a new mesh you will have to got through the following steps
1. Save your boundary conditions with //file/wbc TUI command
2. Save your converged solution into an interpolation file file->interpolate->write data
3. Open your new mesh and scale it
4. Read back boundary conditions with //file/rbc TUI comand
5. Interpolate the old solution on the new mesh file->interpolate->read data
6. Continue calculation
Note that this approach does not work with the dpm model since dpm sources are not saved in the interpolation file.
Good Luck
RoM
Gambit problems Althea FLUENT 22 January 4, 2017 03:19
grid dependancy gueynard a. Main CFD Forum 19 June 27, 2014 21:22
3D Hybrid Mesh Errors DarrenC ANSYS Meshing & Geometry 11 August 5, 2013 06:42
New geometry in tutorial mixer2d unphysical solution for fine mesh christinasmuda OpenFOAM Running, Solving & CFD 6 January 16, 2009 07:11
Mesh Independent Solution Danard Main CFD Forum 1 December 5, 2002 07:32
