Fluent UDF's / dynamic meshing errors
Old   October 21, 2005, 06:35
Default Fluent UDF's / dynamic meshing errors
Peter
Good morning all
I am trying to model an aerofoil starting motion abrubtly. I have written a UDF which basically says
if time < t1 then velocity = 0 else if time < t2 then velocity = x else velocity =0
so that should start off with nothing moving. The aerofoil should then move a short distance and then stop.
The problem is, when I try to run the problem, I eventually get an error message. Sometimes this is 'Segmentation violation', sometimes 'Bus error'.
I have a feeling that this is because the remeshing process cannot cope - sometimes the error is due to negative cell volumes.
Can anyone give me a hint as to how I can solve these problems? Or if anyone can think of an easier way to model the problem, that too would be helpful.
Thanks all,
Peter
Old   October 21, 2005, 10:12
Default Re: Fluent UDF's / dynamic meshing errors
Peter
I think I found the solution. Playing around with the dynamics mesh parameters - especially minimum and maximum cell volumes - and using very small time steps (~0.005s) seems to elimate the problem.
Peter
Old   November 6, 2005, 03:36
gaohongliang
I think you should apply for DEFINE_CG_MOTION ,The model might be useful for you
Building OpenFOAM1.7.0 from source ata OpenFOAM Installation 46 March 6, 2022 13:21
FLUENT Journal File Errors cfd23 FLUENT 4 July 14, 2010 04:12
Dynamic Mesh Can not Be Used in FLUENT 12.0 lzgwhy ANSYS 1 April 18, 2010 18:19
Using compiled UDF:s in different Fluent versions S H FLUENT 1 September 12, 2007 03:40
dynamic meshing option arehman Main CFD Forum 4 June 27, 2004 02:55
