November 29, 2005, 10:40 |
Getting convergence with unsteady problems
As a rule of a thumb, can I say that when running an unsteady simulation in any turbulence model, when I achieve a periodic oscillation in my residuals and in mass-weighted average plots, etc. solution has converged?
If not, this means that mass-weighted average quantities must flatten like in steady simulations? Thanks! |
November 29, 2005, 16:56 |
Re: Getting convergence with unsteady problems
Monitor a parameter like Lift or Drag, when they converge then it means your solution has converged.
Matt |
November 29, 2005, 17:12 |
But in unsteady these parameters I don't think they keep constant: won't they be fluctuating according to also fluctuating velocity and pressure fields?
November 30, 2005, 10:57 |
You reach a point where they do not oscillate much hence you can assume that the solution has converged. However, you can still write a PERL script to average out the final results.
Matt |
December 1, 2005, 13:13 |
OK Matt, many thanks!
Then If I've understood well, when I am in unsteady problems I will get the convergence when my parameters of the flow (mass-weighted average and/or drag-coeff, etc.) have a (little) periodic oscillation, doesn't it? |
conditions for unsteady problems | dvdromnu | OpenFOAM Running, Solving & CFD | 5 | November 9, 2009 02:15 |
Convergence of CFX field in FSI analysis | nasdak | CFX | 2 | June 29, 2009 01:17 |
unsteady flow problems | Daniel | FLUENT | 0 | January 25, 2009 23:54 |
convergence for an Unsteady simulation | Palani Velladurai | FLUENT | 1 | March 19, 2007 10:56 |
Unsteady simulation convergence | Tomislav | Main CFD Forum | 1 | December 6, 2006 07:53 |
