Meshing volume
Old   December 6, 2005, 07:01
Default Meshing volume
F.A.
I have a truck (volume) model which i subtracted from a brick as the ambient domain. After meshing the surface of the truck with 'submap' and 'pave' i tried to mesh the whole volume, but neither 'hexa' nor 'tetra' option works. Can anybody make a proposal how i could handle this problem. Thanks in advance
Old   December 6, 2005, 15:55
Default Re: Meshing volume
AJG
U r probably meshing using gambit, personally I believe that gambit is not good at all for meshing, however, I recommend you to break ur big domain into several small domains and the wall between these domains call it "interior", the process of meshing this way takes longer but it is easier to mesh.
hope this help
Old   December 8, 2005, 06:30
F.A.
Thanks a lot. I am gonna try it that way... Should i keep the whole geometry connected while splitting or is it better to create independent blocks?
Old   December 12, 2005, 01:31
Gede
I guess u should make new independent blocks, but the interior boundary condition needs common face for connecting volume/block.
'Tetrahedral meshing has failed for volume...' Murat FLUENT 5 February 19, 2011 04:22
On the damBreak4phaseFine cases paean OpenFOAM Running, Solving & CFD 0 November 14, 2008 21:14
Volume Meshing & Face Meshing? singularity of grid ken FLUENT 0 September 4, 2003 11:08
volume meshing nikita FLUENT 1 July 3, 2003 01:25
Patran Volume Meshing Deb CFX 19 April 17, 2003 10:56
