UDF error
Old   December 15, 2005, 06:05
Default UDF error
Ale
Hi, can anybody help me to give an interpretation to this error message?
Error: get_udf_function: function p_diff has wrong type: 2 != 0 Error Object: ()
p_diff is a diffusivity as defined in a DEFINE_DIFFUSIVITY macro. I used it successfully to evaluate diffusivity for some User Defined Scalars. Now, I am trying to use it for a mixture. What should I change?
Thanks a lot in advance,
Ale
Old   December 15, 2005, 06:22
Default Re: UDF error_Solved
Ale
I'm sorry, I found the mistake...It just did a bad selection in the menu..Forget my question. Sorry.
Ale
Problem with UDF compiling for kTkLW model Wantami FLUENT 0 July 18, 2011 06:11
ParaView for OF-1.6-ext Chrisi1984 OpenFOAM Installation 0 December 31, 2010 07:42
Accessing phi from a fvPatchField at same patch johndeas OpenFOAM 1 September 13, 2010 21:23
Installation OF1.5-dev ttdtud OpenFOAM Installation 46 May 5, 2009 03:32
Problem with compile the setParabolicInlet ivanyao OpenFOAM Running, Solving & CFD 6 September 5, 2008 21:50
