Error in meshing
Old   January 5, 2006, 02:04
Default Error in meshing
Mannsonu
Hello While meshing following error comes. Initilization failed to mesh nodes. ERROR:TG_mehs_Domain failed with error code 1 ERROR:Tetrahedral meshing has failed for volume 35 This is usually caused by problem in the face mesh.Check the slewnesses of your face mesh and make sure the face mesh sizes are not too large in areas of small gaps. Please give the solution to remove the above error. Thanking you Mannsonu
Old   January 6, 2006, 00:47
Default Re: Error in meshing
sharuk
check ur edge mesh setting and then do face mesh and check if any large gaps r there or not.
Old   January 6, 2006, 01:03
MannSonu
Thanks, In my problem there is a container of 1800*3700*2400mm and in that there is sheet of 0.672mm thicknes and 770 mm width and 1300 height. i first subtracted the sheet from container. and then meshing then above meshing problem given
From MannsSonu
Old   January 6, 2006, 03:46
sharuk
since ur sheet is very thin(compared to other dimensions), give a proper interval size to ur sheet thikness and proceed, else use size function,
[ANSYS Meshing] Migrating from GAMBIT to ANSYS Meshing David-CFD ANSYS Meshing & Geometry 1 April 1, 2011 05:22
Best Meshing scheme for Cylinder Nutrex Main CFD Forum 4 July 29, 2008 11:03
Meshing locks workbench window. andy2o CFX 0 February 1, 2008 05:01
Singularity of grid?Volume meshing vs face meshing Ken Main CFD Forum 0 September 4, 2003 11:09
Volume Meshing & Face Meshing? singularity of grid ken FLUENT 0 September 4, 2003 11:08
