T-Grid / Gambit import and export
Old   January 3, 2006, 14:37
Default T-Grid / Gambit import and export
Riaan
Hi guys, this is the process I want to follow - but I am unsure how to do it:
1) Build surface mesh in Gambit (I can do this) 2) Import surface mesh into T-grid and build boundary layers (I can also do this)
...3) How do I import the T-grid mesh with boundary layers back in Gambit?
Old   January 6, 2006, 00:53
Default Re: T-Grid / Gambit import and export
sharuk
in gambit, file->import->mesh
Old   January 6, 2006, 08:30
Riaan
Yeah, I tried that, but it takes forever! Do I import 3d or Surface?
To date, the progress bar runs to 90% (1 million node mesh), and just hangs there
Old   January 6, 2006, 10:16
sharuk
go to defaults in gambit and change the tri mesh value to -1, it may work, jus give a trial,
mesh missing after export in gambit morteza08 ANSYS Meshing & Geometry 1 July 26, 2010 01:10
mesh missing after export in gambit morteza08 Main CFD Forum 0 July 23, 2010 02:19
SketchUp 3D model import to Gambit or Fluent Steve Johnson FLUENT 0 February 8, 2009 14:21
Errors running allwmake in OpenFOAM141dev with WM_COMPILE_OPTION%3ddebug unoder OpenFOAM Installation 11 January 30, 2008 20:30
Importing I-DEAS unv file hbetb FLUENT 1 August 10, 2001 13:22
