Accessing values from other cells/thread
Old   January 17, 2006, 02:04
Default Accessing values from other cells/thread
leonard
Does anyone know how can I access values from cells in other thread? I need to use the values to set my BC at the wall. I've tried using Thread *t = Lookup_Thread(d,n), but fluent also gives me segmentation error. Can anyone please advice me on this?
Any help is appreciated. Thank you.
Old   January 17, 2006, 10:33
Default Re: Accessing values from other cells/thread
RoM
Tracking segmentation errors is really hard because its fluents standard error message. Posting your source (if its not confidential) would help to identify the problem. One possible problem could be the wrong usage of the thread pointer returned by Lookup_Thread. It can either be an cell thread (n refers to fluid/solid zone) or face thread (all other zones). Using a face thread in a macro that requires a cell thread (like C_T(c,t) ) or vice versa will give you a segmentation error.
RoM
Accessing LES Delta Values From Solver Code mchurchf OpenFOAM 4 June 12, 2023 12:55
Accessing boundary values DoHander FLUENT 0 January 7, 2010 08:44
Accessing node values using a UDF Nico FLUENT 2 December 20, 2007 02:50
Accessing Shear Rate Values in Subroutines Daniel Lattin Siemens 0 January 10, 2007 17:59
UDF help on accessing values shashikant FLUENT 0 December 22, 2005 09:41
