Monitor point
Old   January 24, 2006, 09:07
Default Monitor point
Frank
I want to export Static pressure from an unsteady calculation at different points using the monitor panel. I defined my points, and set static pressure in the surface monitor. But I don't know what to specify in the "report type"? There is several option for a surface, but what happen for a point? I used "sum", "Integral"...for 3 differents point and obtained exactly the same results for all the points.... Any idee? thanks in advance.
Frank
Old   January 24, 2006, 18:00
Default Re: Monitor point
Thomas
You should create a surface point and select a vertex average report type.
thomas
Old   January 25, 2006, 12:22
Frank
It is exactly what I've done, but results are strange...close data whatever the point location, which is not the case.
Thanks anyway
Frank
Old   January 25, 2006, 22:52
Muhammad Shakaib
You can check whether the points are located at the right place using display-contours(unfilled)-surfaces(surface points)
Old   January 27, 2006, 11:11
Anindya
Use the area weighted average.
